anxh
Dec 31, 2017Tutor
Macbook pro connection to ex6150
I cannot connect my macbook pro to the EX6150 extender. I am the UK and just upgraded by homw hub from a BT Hub 4 to a Hub 6. The connections through the 4 worked fine and my Amamzon Firestick and iP...
DarrenM
Jan 04, 2018Sr. NETGEAR Moderator
Have you tried to remove the network from the macbooks wireless settings then connect to it again?
DarrenM
anxh
Jan 08, 2018Tutor
And very odd, as Amazon Firestick, Satellite TV box and iPhone all connect and load/stream fine through the Netgear Extender - just not my Macbook.
