Marco_Williams
Dec 06, 2018Aspirant
Mesh extnder keeps dropping
I have the AC3000(ex8000) X6s Tri-band for a few months.and ever couple of days it will just drop all connected devices (both wired and wifi)
I am on firmware 1.0.1.186
Disabled Smart connect
E...
DexterJB
Dec 09, 2018NETGEAR Moderator
Hi Marco_Williams,
Welcome to the community!
I have sent you a message. Please check your inbox.
Dexter
Community Team
Marco_Williams
Dec 10, 2018Aspirant
Thanks DexterJB. I just responded to the message
- Marco_WilliamsDec 16, 2018Aspirant
DexterJB I sent the tech the information, but still have not heard anything back. I perfer them to email me what to do. The Mesh extender keeps saying that my Nighthawk R9000 is not broadcasting the 5G band but it is. And the Max throughput light on the extender does light up (it used to a few days ago).
I have done a factory reset on both and used the wizards (instead of manually, setting them up) and I still have the issue with the Mesh dropping.
I have disabled the following on the router (R9000 Router Firmware Version V1.0.4.12)
QoS
Smart Connect
WMM (Wi-Fi multimedia) settings (2.4GHz b/g/n)
WMM (Wi-Fi multimedia) settings (5GHz 802.11a/n/ac)
Not sure what else to do at this point, since I bought these at the same time and bought them together because they basically are made to work with each other and make the whole home networking eaiser.
- westcedar1Jan 16, 2019Aspirant
I am having the exact same issue. It drops more than connected. Did you ever figure out a solution? I am about ready to go to a new solution and slam Netgear on reviews for this product. I have a Netgear Nighthawk router and things are worse with this product.
- Gert-JanJan 17, 2019Aspirant
Me too. Did even a fully clean installation (factory reset) for both the extender and my router (R7000). Pattern is the same all white lights are all on at the extender but: (1) connection with router drops and/or (2) there is a connection with the router but no internet and/or (3) can't get an IP adres for devices and/or (4) app says there is no 5G connection with the router but there is.
Tried differented setting like channels/same or other SSID for 2.4 and 5/static dynamic IP, ect
Frustated :-(
What to do?
