Marco_Williams
Dec 06, 2018Aspirant
Mesh extnder keeps dropping
I have the AC3000(ex8000) X6s Tri-band for a few months.and ever couple of days it will just drop all connected devices (both wired and wifi)
I am on firmware 1.0.1.186
Disabled Smart connect
E...
Marco_Williams
Dec 10, 2018Aspirant
Thanks DexterJB. I just responded to the message
Marco_Williams
Dec 16, 2018Aspirant
DexterJB I sent the tech the information, but still have not heard anything back. I perfer them to email me what to do. The Mesh extender keeps saying that my Nighthawk R9000 is not broadcasting the 5G band but it is. And the Max throughput light on the extender does light up (it used to a few days ago).
I have done a factory reset on both and used the wizards (instead of manually, setting them up) and I still have the issue with the Mesh dropping.
I have disabled the following on the router (R9000 Router Firmware Version V1.0.4.12)
QoS
Smart Connect
WMM (Wi-Fi multimedia) settings (2.4GHz b/g/n)
WMM (Wi-Fi multimedia) settings (5GHz 802.11a/n/ac)
Not sure what else to do at this point, since I bought these at the same time and bought them together because they basically are made to work with each other and make the whole home networking eaiser.
- westcedar1Jan 16, 2019Aspirant
I am having the exact same issue. It drops more than connected. Did you ever figure out a solution? I am about ready to go to a new solution and slam Netgear on reviews for this product. I have a Netgear Nighthawk router and things are worse with this product.
- Gert-JanJan 17, 2019Aspirant
Me too. Did even a fully clean installation (factory reset) for both the extender and my router (R7000). Pattern is the same all white lights are all on at the extender but: (1) connection with router drops and/or (2) there is a connection with the router but no internet and/or (3) can't get an IP adres for devices and/or (4) app says there is no 5G connection with the router but there is.
Tried differented setting like channels/same or other SSID for 2.4 and 5/static dynamic IP, ect
Frustated :-(
What to do?
- Marco_WilliamsJan 17, 2019Aspirant
Support contacted me a few days after the post with a beta firmware. I did not install it because I started having problems with my router itself. I eventually just gave up.
- Gert-JanJan 19, 2019AspirantAll my problems are solved! What I did: factory reset voor al devices, latest fm voor all devices, new ssid + password, made sure that every device on the networks forgets the old ssid, made a different ssid and password for 2.4 and 5, bought a extra extender, gave both extenders a fixed IP (not x.250 (!)). The extenders use the x.250 for other purposes.
Just to make sure I bought an EX7000 as extra extender. This wat infounded out that it wasn’t alone what caused all the troubles (!)
Now enjoying up to 600mbps at the attic!!
