Bigrich64's avatar
Bigrich64
Follower
May 18, 2023
mod. EX6150 not connecting to spectrum fiber opt, wifi
I can’t get Mod. EX6150 to connect to spectrum fiber opt. Wi-Fi. It does not show up in available networks on my iPad or iPhone.
any help out there ?
  • plemans's avatar
    what router are you connecting it to?
    Did you set it up using the push button WPS option?
    If so, factory reset the extender  and set it up using the installation assistant.
    To factory reset, push and hold the reset button for 7-15 seconds while powered on.
    Here's a video of how to use the assistant.
    https://www.youtube.com/watch?v=yJVklshxBMk
  • Troubleshooting steps:
    1. Verify that the EX6150 is properly plugged into a power source and turned on.
    2. Confirm that your Spectrum fiber optic connection is working properly by checking other devices connected to it.
    3. Reset both your EX6150 and your Spectrum fiber optic modem/router by unplugging them for 30 seconds, then plugging them back in.
    4. Check if the latest firmware version is installed on your EX6150. You can do this by logging into the device's web interface, navigating to 'Administration' > 'Firmware Upgrade', and clicking 'Check for Updates'.
    5. Try placing the EX6150 closer to your Spectrum fiber optic router/modem or directly connect it via Ethernet cable to see if this resolves the issue.
  • NetGear EX6150 is a Wi-Fi range extender that provides an excellent solution to slow internet or dead zones in your home or office. This device can extend your wireless network coverage by up to 1200 square feet, making it ideal for large homes with multiple floors and rooms. It uses dual-band technology to provide maximum speeds of up to 1.2Gbps and support for all Wi-Fi standards.
    Setting up the NetGear EX6150 is easy and straightforward, thanks to its user friendly web interface. You can also use the NetGear Nighthawk app on your smartphone or tablet for quick installation and management of your network settings. Once set up, this range extender works seamlessly with any router, enabling you to enjoy uninterrupted connectivity throughout your home.
