Major9144
Sep 08, 2022Follower
Model EX7300v2 after power outage
We had a momentary power outage last night, so short that nothing was affected but my EX7300v2. The power light has been flashing green since then, indicating that it is rebooting, but otherwise the...
Sep 08, 2022Guru - Experienced User
Its just constantly flashing green?
Did you try factory resetting it? Push and hold reset for 7-15 seconds while its powered on.
If that doesn't work, you can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
