Cirus
Feb 27, 2018Follower
Model: EX7500 NOT SEEN ON COMPUTER
Purchased just a few days ago, Plugged into power all LED's blue and firm except 2.4Ghz solid amber. Unit does not connect to router Does not come up on list with NETGEAR.EXT
jvasanth1984
Feb 28, 2018Virtuoso
Hi Cirus,
Perform reset and try to look up for NETGEAR_EXT. You can setup the device by the help of below links and check lights on it based or the article shared.
https://kb.netgear.com/000044738/How-do-I-set-up-my-Nighthawk-Tri-band-WiFi-Range-Extender-using-WPS
