jeffreyP57
Oct 22, 2019Aspirant
Model3110 AC750 WiFi range Extender
My AC750 model 3110 needs updated.However,when I go to the downloads page,it keeps giving me a link to go to.I do,then it does it all over again. help!!
I just tried it and was able to download the file fine. I would try using a different browser. Try chrome, edge, firefox. Or if you're using one of those, switch and try a different one.
- jeffreyP57Aspirant
When I click on the file,it says corrupt disc image file.I've run sfc/scannow.No help.
When you click on it to download it or to install it? A better description of where the process is failing will help me instead of just general troubleshooting.
If its for install, you have to extract it first and then follow the firmware install instructions.
https://kb.netgear.com/000057115/How-do-I-update-the-firmware-on-my-NETGEAR-WiFi-Range-Extender
If it still doesn't work, try a different computer.
