StephanZabel
May 23, 2016Aspirant
modify WLAN-channel | EX6200
Hi Folks, i am looking to modify the wifi channel, but i can't see any possibility to do that. When i am in setup of my range extender (WLAN ->Setup), the button for Wifi-channel(2,4GHz) is grey ...
- May 23, 2016
Hey!
I've now modified the Wifi-channel of myspeedport v724v typeA to channel 9 and this channel was taken over by EX6200. So, it seems, that the extender have to use the same channel as the router...somehow logical :)
thanks!
Well, another short question: why i cannot see the 5GHz-Wifi, when searching through existing Wifi's? Do i have to have a special Wifi-Adapter in the computers? I tested both windows and mac-Machines. Only Mac shows the high-performance-Wifi..PCs can't show 5GHz. (Yes, i have turned it off as i wrote i the last post, but i just tested it now, and it seems that there is no 5GHz-Connection possible?
My Wifi-Adapter: Realtek RTL8723BE Wireless LAN 802.11n PCI-E NIC
Thanks in advance
Stephan Zabel
TheEther
May 23, 2016Guru
Do you, perhaps, have FastLane turned on? FastLane will dedicate an entire band (e.g. 2.4 GHz) to connecting with the router and must use the channel as the router. You will need to either change the channel on the router or turn off FastLane.
- StephanZabelMay 23, 2016Aspirant
Hey!
Thanks for the fast answer!
Nope, Fastlane is off. Extender works in basic mode. Furthermore I have turned off the 5GHz-Option, because this signal is not stable. 2,4Ghz works stable in these rooms..
So, i check my speedport-router for another channel. I will report, then :)
thanks!
Hey!
thanks!
Thanks in advance
Stephan Zabel
- DarrenMJun 01, 2016Sr. NETGEAR Moderator
Hello StepahanZabel
That is correct the wireless card in your device also has to support 5ghz in order to see the network.
DarrenM
