Mt3's avatar
Mt3
Follower
Aug 08, 2020
Moved to new home nighthawk X6S
I have moved from the original place I set the unit up at, at my new place it will not connect to new router. I tried the trouble shooting and it stil says cant locate the new router.
1 Reply
  • plemans's avatar
    Which router are you using?
    What modem/gateway are you connecting it to?
    Did you factory reset the router and then follow the install guide?
    It can be found at netgear.com/support/    go there and type in the model number and it'll take you to the support site.
