Gewgaws
Jul 16, 2021Aspirant
MR60 not seeing firmware update
I have an MR60 with two MS60 sattelites (purchased from Costco). After initial setup I was able to update the firmware through the Nighthawk app to v1.0.6.102 (the same version firmware is running o...
Dec 23, 2021Guru - Experienced User
You can manually update FW:
Update the MS first then MR lastly.
Netgear has set up a community forum specifically for the NightHawk MESH products. Most of the people who watch that forum are more likely to have experience with NH MESH products and know how to work it better than those of us who follow this forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Thank you.
MoePa wrote:
I have the same issue of it not finding the update and I am stuck at 116.
i also had the the same issue before I had updated to 116. 116 update occurred months after it was released on their website.
MoePa
Dec 31, 2021Guide
Thanks was able to manually update.
