OrangeCrush1968's avatar
Apr 28, 2025
MR70 Loses Advanced Routing Settings
NightHawk #MR70 mesh system V1.0.3.34_2.0.58) is set up with advanced routing to some custom TCP/UDP ports. After a while (ranging from days to weeks), the advanced routing stops.
When I go in to look at the settings, the list is blank. If I try to add the rules again, the system presents the message that the rule conflicts with existing service. However, when I try to search the rule it does not exist and the list remains blank.
The only (temporary) solution I've found is to completely factory reset the system and re-create all the rules. Unfortunately after a few days the problem returns.
I've tried backing up the settings and restoring from the backup, however the same problem persists upon restoration, even if the settings are backed up after a freshly reset system which should be error free.
1 Reply
  • plemans's avatar
    It makes me think you do have something that is causing issues if it happens even during the restore.
    One option to try is to assign address reservations for the devices that are using the advanced settings.
