wthoward0905
Aug 22, 2016Aspirant
Multiple EX2700
I live in a 3 level townhome. Can I have 2 extenders on the same network, one on the upper level and another on the lower level?
- DarrenMSr. NETGEAR Moderator
Hello wthoward0905
Yes you can but make sure both extenders are connected to the main router and do not connect extender to extender.
DarrenM
- wthoward0905AspirantThank You! đ I appreciate your response. One other question would the network for both remain the same like L5LSH8_EXT?
Hello wthoward0905
You can leave them the same SSID or make them all different.
DarrenM
