paknakal
Jul 22, 2011Aspirant
Multiple WNDR4000 Routers as APs
I am looking to set up 1 router with 5 or so access points around the house, all attached back to the router via hardwire. I like the look of the WNDR4000 for the router, but couldn't find a good acc...
jmizoguchi
Jul 22, 2011Virtuoso
yes,,,,,,,,,,,,,,,,,,
that is the diagram show isn't it? :)
you can choose to buy AP is your choice.
otherwise makes no difference
Will wifi work as seemlessly as it would if I used actual Access Points? In other words moving around the house will be seemless?
