paknakal
Jul 22, 2011Aspirant
Multiple WNDR4000 Routers as APs
I am looking to set up 1 router with 5 or so access points around the house, all attached back to the router via hardwire. I like the look of the WNDR4000 for the router, but couldn't find a good acc...
Retired_Member
Jul 22, 2011You might rethink this.............since there are only 3 channels (2.4ghz) that do not overlap ......unless your home is extremly large you may end up creating your own interference. 5g I believe has 4 non-overlapping channels. If you happen to be in a room that pics up two AP's using the same channel I would think that would be a problem.
