will55_55
Jan 01, 2019Aspirant
My AC1200 WiFi Range Extender keeps disconnecting
I just bought the AC1200 wifi range extender 3 days ago and everynight so far it disconnects from the router. I have to wake up every morning and reconnect it. I have restarted the extender and it st...
Jan 02, 2019Guru - Experienced User
AC1200 is a speed rating, it's not the extender model number (which starts with an EX). Can you give us the model number, and the firmware you are running?
Note you do have access to paid Netgear support (my.netgear.com) for 90 days after purchase, so you could also ask there.
will55_55
Jan 21, 2019Aspirant
It’s an EX6110. It disconnects every night and I have to reconnect it every morning.
- Marz24Jan 22, 2019AspirantBro I have the same product. Mine is not disconnecting at all once connected to my router. But I have different problem, my 5ghz is not connecting to my router at all. Only the 2.4ghz is working fine. I wonder if your 5ghz is able to connect to your router?
