nlbngr
Feb 18, 2019Tutor
My EX2700 won't connect to my new router
My EX2700 worked fine with my old router, but since I got a new router I haven't been able to connect the two.
When I plug the extender in next to the new router and then go to "mywifiext.net" ...
Christian_R
Feb 21, 2019NETGEAR Employee Retired
Hi nlbngr - Please perform a factory reset on the extender by pressing the small button with a pin/needle. After, locate the "NETGEAR_EXT" network and connect to it. Once connected, browse to www.mywifiext.net and follow the setup instructions.
~Christian
- nlbngrFeb 22, 2019Tutor
Thanks Christian,
I hadn't tried that yet... I don't know why. It didn't work though.
I'm still getting a connection between the extender and my computer/devices, but no apparent connection between the extender and the new router.
It's frustrating because it worked fine with the old router. I don't suppose it should matter that the old router was DSL and the new router is Cable?
- Christian_RFeb 22, 2019NETGEAR Employee Retired
Hi nlbngr,
The difference between the 2 routers shouldn't be an issue. Just to clarify, for your devices that are connected to the extender do they have access to the internet?
~Christian
- nlbngrFeb 24, 2019Tutor
Christian,
No... my devices cannot connect to the internet when I have chosen my extender's network.
I even tried connecting via my Kindle, thinking that perhaps there was an iussue with my computer's network adapter, but I get the same result: "You are not connected to your extender's WiFi network".
