Sampatel904
Oct 05, 2020Aspirant
My extender not showing 5ghz even if 5ghz signal broadcast is on..
I have netgear ac750 wifi range extender ex6100 i already set it up with my router but 2.4 ghz network shows in my phone and my ipad but 5ghz simple not showing on my any device for i don't know why.....
Oct 06, 2020Guru - Experienced User
You can disable the "onewifi" feature. That'd allow you to name the wireless bands whatever you'd prefer.
Sampatel904
Oct 07, 2020Aspirant
I had check every setting in my router but got nothing like onewifi features please help...
How can i enable 5ghz option and also there is an option called fastline technology would this feature can help me to fix this???? I also attached screenshot so you can get hardware information and all that things...
- plemansOct 07, 2020Guru - Experienced User
In your screen shot, you're not on the wireless settings page. Did you follow the instructions I linked to?
or tried it with your pc?
- Sampatel904Oct 10, 2020AspirantNo actually there is no option that you mentioned see this is my wireless setting on extender...
- plemansOct 10, 2020Guru - Experienced User
why don't you log in through a computer so we can see the whole page and not just a little bit of it on a mobile.
