Hlalibe's avatar
Hlalibe
My Netgear WN30000RP wifi extender does not deliver IP address to incoming connections
Hello all,   I have this device for 3 years now, latest firmware (also tried previous firmware). Did a factory reset and re-configured.   My base station (Zyxel router, not new, used to work with...
  • Hlalibe's avatar
    Hlalibe
    Jan 10, 2017
    Hello,
    no,
    but in the mean time i made another factory reset and started all over the configuration with the setup wizard, and it's working fine now.
    So not sure what was the initial proplem,
    but thanks anyway for your feed-back,
