leefoo
Nov 10, 2015Aspirant
My password doesn't work now for my WN1000RP and every tip has failed (2nd request)
I tried resetting the modem, I tried the NETGear Genie on my IPAD, I tried turning off the Extender, I tried logging on thru the INternet.....nothing worked. It neither takes my regular password or t...
- Nov 13, 2015
Thanks
The one that FINALLY worked (thank God) is that I reset my settings back to default and then started over. (I didn't even get to try the NEtwork Profile deletion)
Everything has worked well now.
Must've been that d**n IOS 9 update.
leefoo
Nov 12, 2015Aspirant
nhann wrote:Hi leefoo,
Are you experiencing the same connection issues when you connect to the WN1000RP with another computer/device?
Please see the following discussion on iOS 9 connectivity issues:
https://discussions.apple.com/thread/7219555?tstart=0
Also see Apple's help page:
https://support.apple.com/en-us/HT204051
Yes....my wife can't connect either now. I will check those links out and see if they are helpful.
I saw this on another thread:
"Hi JJ249,
Please confirm that the reset was a reset to factory defaults (page 31 of 35) :http://www.downloads.netgear.com/files/GDC/WN1000RP/WN1000RP_UM_20Feb2013.pdf
Which router is connected to the WN1000RP?
On the device (such as laptop) that you are using to the WN1000RP, can you please delete the Network profile and reconnect?
For example, on a windows PC, you might already have in your networks the profile to your extender. Remove this network profile and reconnect."
How do I do this?
Thx
Lee
leefoo
"How do I do this"............referring to deleting the profile on my PC. I couldn't find it anywhere.
Thx
Lee
