NG_2015
Aug 21, 2015Aspirant
My router issues the message sending OFFER to IP-address
Every second my router issues the message "08/21/2015 13:43:22 sending OFFER to 192.168.2.2". That IP-address used to belong to my Netgear WN3000RP repeater, which I do not use anymore. Can someone ...
- Aug 31, 2015
The setup for the WN3000RP is through a web browser or WPS, and does not require any software to be installed on the PC.
There is however NETGEAR Genie, which is optional software that can monitor settings for NETGEAR products.
nhann
Aug 27, 2015NETGEAR Employee Retired
Please try resetting the Experia box V8 to factory defaults.
You can also try visiting the KPN forums for help on the Experia box
NG_2015
Aug 29, 2015Aspirant
Dear nhann,
Thank you for your help. I just reset the Experia Box V8 to the factory defaults -- twice to be precise, from the dashboard and by using a paperclip at the back of the Experia -- but unfortunately it did not have any result.
I also posted this question on the KPN forum, but people only say well that is a strange problem, but to my regret no one has a solution.
It is really peculiar, the IP-address the Experia Box V8 is sending this message to, belonged to a Netgear repeater, which is not in use anymore and this IP-address is now taken by something else.
Paul
