NG_2015
Aug 21, 2015Aspirant
My router issues the message sending OFFER to IP-address
Every second my router issues the message "08/21/2015 13:43:22 sending OFFER to 192.168.2.2". That IP-address used to belong to my Netgear WN3000RP repeater, which I do not use anymore. Can someone ...
- Aug 31, 2015
The setup for the WN3000RP is through a web browser or WPS, and does not require any software to be installed on the PC.
There is however NETGEAR Genie, which is optional software that can monitor settings for NETGEAR products.
NG_2015
Sep 01, 2015Aspirant
Dear nhann,
Thanks for your clear reply. The question is 'solved': KPN will supply a newer model Experia Box.
All the best,
Paul
