amkor
Feb 02, 2016Aspirant
My universal wifi range extender wn2000rpt v3 falls asleep
Hi, I'm new here, and with very little experience in the subject, so: I've been using this wifi extender for couple years now in my home office (our Comcast wifi router is in the other end of our...
doraemon
Feb 05, 2016Prodigy
First thing's first.
Check other power outlet.
Check another power adapter with the same voltage specs.
If the same result, the hardware might be starting to degrade.
See if re-flashing the firmware will work.
Download the firmware here.
Upgrading the firmware can be done by accessing mywifiext.net.
- Log in to the device using a Web browser. The URL is http://www.mywifiext.net.
- Click Maintenance > Firmware Upgrade
- Click Browse and find the file you just downloaded.
- Click Upload. While the firmware is loading, do not interrupt the upgrade process.
amkor
Feb 07, 2016Aspirant
I reset the extender, went thru the installation precedure again, and both my iPhone and iMac recognize the extender (NETGEAR_EXT) but I don't get connection to the internet, so no way to update the firmware that I downloaded....
