kita95
Sep 08, 2016Follower
my wifi connection drops when i unplug the ethernet cord from my range extender
Hi,
i brought a EX6100 AC750 and every time i unplug the ethernet cord that connects the wifi modem to the extender so i can move the extender to another place it drops off and doesnt connect back.
Ive gone through the configuration process a couple of times and its not doing anything, i have also tried connecting the modem and extender through WPS a couple of times and it doesnt work. I have also tired with the rest button but am sill having no luck
what can i do to fix this?
Thanks
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello kita95
Make sure your routers wireless security is set to WPA2 and you also may want to try and change the wireless channel.
DarrenM
