alenconnais
May 22, 2016Aspirant
My WN2000rpt V2 has ip address conflicts
Hello, My extender wn2000rpt v2 has been working perfectly. For some reasons, it has now some ip address conflicts, My router sees the wn2000rpt v2 ip adress as 192.168.1.131 (and so on when reset...
alenconnais
May 23, 2016Aspirant
searay wrote:
try using address reservations for the extender
Thanks for the advice
As I am not familiar with "fixing" IP addresses, do you mean assign fixed IP addresses with the range 192.168.1.125 to 192.168.1.160?
Also If such is the case, Should I fix it in the extender or the router or both
Retired_Member
May 23, 2016address reservations is an option in the router lan setup, it will assign same IP to a device, It's not static it's still DHCP with a twist you enter MAC address and IP is reserved for that MAC only
try the extender first
