borate
May 07, 2016Aspirant
MyWifiext.net connection
It's working and configured but when an attempt is made to bring up the WEB-based settings interface - while connected to the extender via ethernet or WiFi - it fails with the message "not connected...
DarrenM
May 09, 2016Sr. NETGEAR Moderator
Hello borate
Have you tried to connect to the extender by using the ip address that the router assigns to the device? you can typically find it in the attached devices tab in your router settings.
DarrenM
borate
May 09, 2016Aspirant
Was not able to locate the IP address via router settings. Was able to connect to the extender and request its address - which wouldn't connect. No message, just a time out. Thanks.
- DarrenMMay 10, 2016Sr. NETGEAR Moderator
borate
Have you tried to connect directly to the extender using ethernet connection and then try to log into it using http://www.mywifiext.net
DarrenM
- borateMay 10, 2016Aspirant
Absolutely. That also did not succeed, except after the extender was reset to the default. Only then could I connect via WiFi and bring up the NetGear interface.
