Nemo-2000
Nov 11, 2016Aspirant
N300 connectivity problems
I have a DGN22200v4 router, located upstairs, which runs my WiFi network LAN-1. Downstairs in the lounge is a N300 WiFi Extender which runs LAN-2. There is a laptop in the same room which is configur...
DarrenM
Nov 21, 2016Sr. NETGEAR Moderator
Hello Nemo-2000
Have you tried to factory reset the modem and setup the network again or even back up your config and then load it after the reset?
DarrenM
- Nemo2000Nov 22, 2016Aspirant
Some further investigation suggested a channel conflict.....
My router has always been set to choose a channel automatically and until recently there had never been a problem. Some diagnostics showed that the problem occurred whenever the router chose Channel 1, but not if it chose 6 or 11. My neighbours' (strong signal) WiFi currently is running on 4.
I changed my router to always use Channel 11 (as any other Channel 11 networks in my area are far away with very weak signals) and so far - fingers crossed! - there has been no further problem. I'm just hoping now that my neighbours' router doesn't change to 11 one day :-( Quite why his router on 4 should interfere so badly with mine on 1, but not when mine was on 6, remains a mystery.......
