mervynsamson's avatar
mervynsamson
Follower
May 16, 2017
N300 EX2700 range extender
I tried to reconfigure the Netgear N300, EX2700 wifi extender. I pressed the factory reset button to add it into a new Windows network, but the old device name, ID/password and security information persists. I can't log in to configure the device. It keeps asking for the original ID/password. What should I do?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello mervynsamson
    You will need to hold the reset button down for 10 seconds to factory reset the unit. Then you should be able to set up the unit again.
    DarrenM
