isthisbrian
Apr 30, 2017Follower
N300 EX2700 won't connect with new modem/router
New residence. Our Extender is still paired with old router. Since moving, I can't locate the manual. Is there an easy run down on pairing with a new modem/router? Thanks in advance.
DarrenM
May 02, 2017Sr. NETGEAR Moderator
Hello isthibrian
Yes you will need to factory reset the unit by holding the reset button for 10 seconds then set it up again.
DarrenM
