mosfet's avatar
mosfet
Initiate
Jan 04, 2019
N300 extender doesn't show me password filed in setup wizard
Hi, I am trying to connect a N300 wifi extender as WIFI RANGE EXTENDER with my Netgear DG834G v3 router.
When I enter into N300 page setup I can choose Wifi range extender use, in the next page I can choose my network name.
I do click on my ruter connection (it's Netgear with security WPA2-PSK), in the page "Enter the password (network key) for your existing WIFI network you selected", I can see my network but I don't see any password filed where I can enter my router password.
You can see a screen in attach about my problem.
Can you help me please?
Thanks
1 Reply
  • StephenB's avatar
    Does it help if you check the radio button next to your network name?
    If not, perhaps try a different browser.
