ejfreeman's avatar
Aug 06, 2018
N300 Extender
I have 2 questions:
1. How can I keep the extender from losing its internet connection?  After an hour of no use in the extender, there is no internet .
2.  Can I rename the extender the same name as the router, without the ext added to it?
Ed
Ejfreeman125@gmail.com
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi ejfreeman,
    Welcome to the community!
    1. What is the status of the Router Link LED?
    2. Yes, you can rename it but it will be difficult to identify for troubleshooting purposes.
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi ejfreeman,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
      • ejfreeman's avatar
        ejfreeman
        Tutor
        I reset it back to factory and it is working fine.
        Thank you,
        Ed
