nc2016
Jul 31, 2016Aspirant
N300, no internet connection
After installation all of the lights work and it shows everything is connected. My current router works fine and internet connection is established. When I turn on the extender, all lights still show ...
nc2016
Aug 08, 2016Aspirant
It does have the _EXT. I tried changing the channel on my router, resetting the extender, reconnecting everything. Nothing works. The internet is fine until I connect to the extender. When I connect to the extender I get an error that says "internet unavailable".
DarrenM
Aug 12, 2016Sr. NETGEAR Moderator
Hello Nc2016
I would contact Netgear support if the extender is still under warranty they will be able to troubleshoot some more and figure out if its a issue with the hardware of the extender.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
- nc2016Aug 12, 2016Aspirant
Thank you, I will try that
