Michaelfob1's avatar
Michaelfob1
N300 range extender
The device connects with both WPS and through Netgear instillation app.
However shows NO INTERNET when connecting to any device.
I am guessing security settings on my home WiFi hub need adjusting but really not sure what?
  Please Help
  • Have same problem however initially worked OK and now has just stopped and won't reset (had it 5 weeks). Using the online system means you end up in a virtual loop with no progress... on the phone to support now and will let you know if have any success
      • plemans's avatar
        What router are you connecting to?
        What firmware is on the extender?
