Johncheetham
Sep 07, 2018Aspirant
N300 Wifi extender wont accept password and no Router Link LED
I have the N300 Wifi Range Extender WN3000RPv3.
Using my iphone or Ipad, and using my Routers Password, the Extender says it is incorrect. If I type mywifiext.net it says "You are not connected to ...
- Sep 07, 2018
Did you try unplugging it, and then plugging it in again?
Can you connect a laptop to the extender's ethernet port? That should let you reach mywifiext.net.
Sep 07, 2018Guru - Experienced User
- JohncheethamSep 07, 2018AspirantThanks guys. I found by holding the reset button for 7 secs that cured it.
- StephenBSep 08, 2018Guru - Experienced User
Great!
