Johncheetham's avatar
Johncheetham
N300 Wifi extender wont accept password and no Router Link LED
I have the N300 Wifi Range Extender WN3000RPv3. Using my iphone or Ipad, and using my Routers Password, the Extender says it is incorrect. If I type mywifiext.net it says "You are not connected to ...
  • StephenB's avatar
    Sep 07, 2018
    Did you try unplugging it, and then plugging it in again?
    Can you connect a laptop to the extender's ethernet port?  That should let you reach mywifiext.net.
