Spectre55's avatar
Spectre55
N300 Wifi extender
Hi all,
I just connected an N300 extender.  When connected to the extender, I can access the internet with no problems.  But, when I connect to the main router directly, I have no internet access.  Is this normal?
Thanks in advance
  • Hi Spectre55,
    Welcome to the community!
    1. Please make sure that the extender is connected to the main router's SSID (WiFi name).
    2. What is the model number of your router?
    3. Are you able to go online while wired to the main router?
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Spectre55,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Spectre55,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
    • Spectre55's avatar
      Spectre55
      Hi.  Thanks for the info.  I've been busy at work so I haven't had time to answer.
      I rebooted the router and extender and now everything seems to be working.  Thanks for the assistance!
