richardcordrey
Sep 19, 2018Aspirant
N300 Wifi extender
Hi, This extender has worked fine for two weeks but now will not connect to web pages. All four lights on display are green saying it is connected to my device and main router tncap -ext has a tick n...
Sep 19, 2018Guru - Experienced User
What device is this? Also, what router are you using?
Have you tried powercycling the extender?
richardcordrey
Good afternoon. Thanks for your time.
It is model WN3000RPv3.
It worked fine for two weeks but now internet doesn't work even though all indicators say it,s connected including client light which is lit green.
- StephenBSep 19, 2018Guru - Experienced User
When you said the extender was connected to "my device", what device did you mean?
- richardcordreySep 20, 2018Aspirant
Hi,
This is working now.
Didn't do anything just started working again this morning.
Thanks for your help.
