dom73
Aug 07, 2017Aspirant
N300 WiFi Range Extender Model EX2700
OK, So, I purchased the N300 WiFi Range Extender Model EX2700. I followed the instructions, and all the lights on the extender are showing the right colour. I can see the extended newtork on my lapto...
Smartyuk
Nov 30, 2017Aspirant
Hi Dom73
Did you ever manage to get this sorted? I have almost the same problem. I have connected to my wifi but I want to connect my tablet, when I click on my ext it ask for my password but It does not accept it. So here I am very frustrated I cannot connect my tablet. Can anyone help with this for me please? Thank you
dom73
Dec 07, 2017Aspirant
Hi
Apologies for the delay in responding, I had issues getting logged back in to this forum. I did solve it. I had to buy an ethernet cable. This connects to the extender. The other end goes plugs into your computer. If I remember correctly, once you have the extender connected you log into the Netgear support website which is detailed in the instructions book. From there I found the password. I think it was quite self explanatory once logged in. Be warned though, if your default password is anything like mine for the extender it will be over 40 characters long!! Good luck
- SmartyukDec 18, 2017Aspirant
Thanks for the reply however I am trying to connect my samsung tablet and so cannot plug in a cable, or are you telling me to connect to a computer just so I can get a password? but also it is now out of waranty so can I still get my password? I am not very clever when trying to do computer stuff. What really doe annoy me is netgear dont care unless your stuff is registered and within your guarentee, at the end of the day it is still from them and they have the easy answers. Thank you
