Longbow2000
Aug 06, 2016Follower
N300 WiFi Range Extender, Model WN3000RPv3
Good Day I have a NETGEAR N300 Wireless DSL Modem Router, Model No. DGN2200. It is connected to the ADSL line in the “Home Office” room. In the living room, “three brick walls” way is the NETGEAR N...
TheEther
Aug 06, 2016Guru
The DStv WiFi Connector looks similar like a Ethernet-to-WiFi adapter, similar to Netgear's WNCE2001. It doesn't look like it has any custom software built into it to facilitate downloading of videos. The DStv Explora handles all of the downloading.
Do you have Access Control enabled on the DGN2200? If you do, then you need to grant access to the DStv WiFi Connector while it's connected through the WN3000RPv2 in Scenario 1.
Is the WN3000RPv2 in the same room as the DStv Explora? If it is, then have you tried wiring the DStv Explora directly to the WN3000RPv2 via Ethernet? A wired connection is always superior to wireless.
