JP1950
Dec 23, 2015Initiate
N300 WiFi Range Extender password
My Ipad is usually connected to my Extender. But in the last few days it is asking for a password when I try to connect to the Extender. I set up a password when I first installed my Extender but I cannot find my note with the password writtn down.Is there any way I can retrieve my password?
Don't think there is a way to retrieve it. Just factory reset it and start again with the set-up process
Hope this helps
- clithesProdigy
Hope this helps
- JP1950Initiate
Thanks for advice. I did factory reset and re-installed extender by following instruction bookletPages 6 and 7. Password of router was needed. Worked properly.
