oliveview
Apr 14, 2016Tutor
N300 WiFi Range Extender Stopped Working with iOS Devices...
Hello: I've been using a N300 WiFi Range Extender WN2000RPT for about three years. It is being used to extend the WiFi signal from our wireless router from our ISP. It is also being used to deliv...
DarrenM
Apr 18, 2016Sr. NETGEAR Moderator
Hello oliveview
Have you tried to adjust the wireless channels on the router to see if the extender can receive a better wifi signal? also have you made sure the extender is up to date with firmware. But if you believe that the extender has a hardware issue you may want to contact netgear support if the WN2000RPT is still under warranty.
http://www.netgear.com/support/contact.aspx
DarrenM
