oliveview
Apr 14, 2016Tutor
N300 WiFi Range Extender Stopped Working with iOS Devices...
Hello: I've been using a N300 WiFi Range Extender WN2000RPT for about three years. It is being used to extend the WiFi signal from our wireless router from our ISP. It is also being used to deliv...
oliveview
May 15, 2016Tutor
Okay, I figured out how to access the extender through my computer. However, I have found that I am ALREADY running the most current firmware (1.1.0.12).
So...what should I do?
- TheEtherMay 15, 2016Guru
Proceed to follow DarrenM's suggestion to change the channel used by the extender for it's Wi-Fi network. You should be able to change it on the extender under Settings -> WiFi. See page 20 in the manual (link).
- oliveviewMay 15, 2016Tutor
What am I missing? Every single time I direct my web browser to the www.mywifiext.net address (either wirrelessly or via Ethernet) I get the same screen, with the following tabs:
Setup Wizard
Add WPS Client
Setup
Maintenance
Advanced
Not one of those tabs contains "Settings" nor "WiFi" controls. And in regards to your reference to page 20 in that manual, I also see nothing representing a "Menu" option.
Any ideas why I'm so far off?
Thanks!
Perhaps you have a different version. The manual I linked to is for the WN2000RPTv3, which what you indicated in your post. If you have a WN2000RPTv2 or a WN2000RPTv1, then the menus are different. Actually, I'm not sure that you can manually change the channel on these versions. It's possible that channel selection is handled automatically. You may have to poke around under Setup > Wireless Settings. You can also look at Maintenance > Status and Maintenance > Network Devices to determine if the extender's WLAN interface is up, whether any devices are connected, and whether the extender has a connection to the router.
