Jpeart01's avatar
Jpeart01
N300 WiFi Range Extender taking up all my bandwidth.
I called my isp to complain about slow internet speeds, they looked up my usage and all that jazz. Literally 99% of my bandwidth was being taken up by the extender uploading something. At the time i was closer to the router so I was connected directly to its signal, not the extender. So even with nothing connected to the extender at the time, it was still managing to hog all of the bandwitdh. ...... I change the password frequently, but again, there were no devices connected to it at the time, so its not an issue of others logging on and downloading or uploading or w.e., Any ideas on how to get this fixed? Yes malware scans have been done etc etc.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Jpeart01
    Have you made sure you firmware is up to date? also you may want to factory reset your device and connect it to the router again.
    DarrenM
    • Jpeart01's avatar
      Jpeart01
      I did a hard reset, that sped things up for a whole 5 minutes or so. Not sure how to update the firmware, so no I have not done that. Any advice you could give me on the process?
      • DarrenM's avatar
        DarrenM
        Hello Jpeart01
        Log into your extender by going to www.mywifiext.net use the login of admin/password then go to firmware and click check. Then you should be able to update it.
        DarrenM
