garyshog's avatar
garyshog
Follower
Sep 19, 2015
N300 WiFi Range Extender
I have several extenders in use around the house, and two of them have the same name = EXT2. How do I change the name of one of them, without going through the whole setup process? Thanks.
1 Reply
  • nhann's avatar
    nhann
    NETGEAR Employee Retired
    Hi garyshog,
    Which NETGEAR N300 WiFi extender are you using? (EX2700, WN3000RP, etc).
    The interface is slightly different from the products but you can connect to the extender's WiFi, then login to mywifiext.net
    Navigate to Settings < WiFi settings
    Edit the SSID field and click Save
