garyshog
Sep 19, 2015Follower
N300 WiFi Range Extender
I have several extenders in use around the house, and two of them have the same name = EXT2. How do I change the name of one of them, without going through the whole setup process? Thanks.
1 Reply
- nhannNETGEAR Employee Retired
Hi garyshog,
Which NETGEAR N300 WiFi extender are you using? (EX2700, WN3000RP, etc).
The interface is slightly different from the products but you can connect to the extender's WiFi, then login to mywifiext.net
Navigate to Settings < WiFi settings
Edit the SSID field and click Save
