pseudosu
Jun 14, 2016Aspirant
N300 will only allow one computer to connect at a time (?)
Hello, I have an old dsl line with a static IP address. I was using a mac time machine until it fried and just picked up my Netgear router (WNR2000-- N300 WiFi router) yesterday. After doing the ...
VE6CGX
Jun 14, 2016Master
What is the setting of IP address range on the LAN set up page? Yout set up should be
like 192.168.1.2 - 192.168.1.254 or leave it at default.
- pseudosuJun 14, 2016Aspirant
The IP begins with 208... Is that what you are referring to?
- VE6CGXJun 14, 2016Master
Range has beginning address and ending address. Every device needs an ip address handed out by DHCP. So what is the range?
You have one address, 208? That's it?
Sorry to be clueless-- the tech from my isp told me when i set up my new router to swtich from DHCP to manual and to enter the IP, subnet mask, and a couple of DNS #'s. I'm confused by "range". Are you asking for my IP address? I was given those 4 sets of #'s, and when I enter them into any of my computers they work. I just can't connect to any other computer. Should I be switching back to DHCP after I enter them or something? My options appear tp be : Using DHCP / Using DHCP with manual address / Using BootP / & Manual.
