leojhartiv
Nov 23, 2014Guide
N300/EX2700 drops frequently as extender
I am using the ex2700 as an extender for my apple AirPort Extreme router. The router is located on my main floor and covers most of the house, but there's a long hallway to the master bedroom on the ...
Kaiclubbe
Oct 28, 2015Initiate
Same issue. Green lights, but drops constantly.
nhann
Oct 30, 2015NETGEAR Employee Retired
Hi Kaiclubbe,
Can you please describe your network setup?
Which router are you using with the EX2700?
Are both the EX2700 and router updated to latest firmware?
- dutch135Jan 22, 2016Initiate
I have a WN3000RP with firmware v.1.02.64_1.1.86. It continually drops the signal, despite showing that the source router is within sufficient range. It's the same problem many others report having. It comes back on if I reset it. But that's an unacceptale solution.
