_TERMINATOR_82's avatar
Apr 09, 2017
N600 Range Extender
Model: N600
Latest Firmware (as of 4/9/17)
Windows 10
Home
I installed my extender and it was easy enough. Everything was working fine, meaning all expected lights lit up as they should have. I am able to connect all my devices without issues as well to the new extender and the intended wireless network are named correctly. I recently installed the latest firmware and now the Decice To Extender LED is not lighting up, but all my wireless devices are hooked up fine to the network. I rebooted the device a couple of time as well with no luck. Should I be concerned about this?
Thanks in advance
  • schumaku's avatar
    schumaku
    Your clients are associated wit the N600 exender at all - or still using the router WiFi?
  • All connected to the N600. I made sure to re-connect to the extender after the reboot. Also when looking at the setting via the online client it shows my connected devices using the extender.
