pbegly's avatar
pbegly
Follower
Jul 11, 2016
N600 wifi extender running at 100mbps instead of 600mbps
I purchased a n600 wifi range extender from best buy. I installed the device making sure to put it in an area with already good wifi reach. When I used an ethernet cord to get internet from the range extender to my desktop pc it showed speeds of 100mbps instead of the advertised 600mbps. I would like to know if there is something I missed while installing the device which would remidy the problem.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Pbegly
    You may want to try fastlane mode which if you log into the extender then Advanced then Operating mode.
    DarrenM
