Nathan4wvu1986
Aug 18, 2018Aspirant
N7900-100NS and Nighthawk Mesh x6s IP Issues
In January 2018 I purchased my n7900 and it's been great so far with my only complaint being it's range. So about a month ago, on Prime Day, I purchased the Nighthawk Mesh X6S Extender and that's whe...
Nathan4wvu1986
Aug 19, 2018Aspirant
She connects via WiFi and I have tried to release, reset, and delete the wifi connection from the Mac. Nothing worked.
Aug 22, 2018Guru - Experienced User
Is the EX8000 in extender mode or AP mode?
Have you limited the DHCP server's address range to exclude any static IP addresses? Note that I mean device-configured static IP addresses, not reserved addresses in the router.
Is it still possible to exchange the extender at Amazon?
- Nathan4wvu1986Aug 22, 2018Aspirant
It is running in extender mode, not access point.
As for limiting the number of IPs, unless that's a default setting in either the router or the extender I'm not. Both are running default settings aside from the Wifi name and password. Currently, looking at Netgear Genie I have 19 devices connected to the main router and 1 connected to the extender.
I pulled the dump level and Amazon as always took care of it. I contacted their product support and they're sending out a new unit. Piss pore service on Netgears part. I registered this 3 weeks ago, purchased on 8/17/2018 and they have the SN marked for zero support.
- StephenBAug 23, 2018Guru - Experienced User
Hopefully the replacement from Amazon will resolve it.
It's a router setting,and it wouldn't be default.
If you are using (for example) a 192.168.1.x network, then usually your router's DHCP service will grab 192.168.1.2-192.168.1.254. The router has no idea what static addresses you've assigned, and it will assume that it can assign any address in it's range.
So if you use static addresses, you need to go into the router and ensure that there's a block of IP addresses that the DHCP service won't use. For instance, start the DHCP service at 192.168.1.100 - giving you the plenty of static addresses, and making it easy to separate static from dynamic.
Though a better strategy is to use only DHCP and reserve addresses in the router. That centralizes the IP address management to one device, and it also is more robust. For instance, if you change to a new router that uses 192.168.0.x, all your static devices become unreachable. If you reserve addresses, they will still connect (just with a different address).
There is another cause of duplicate IP addresses though. If you reboot the router, it will clear it's address assignments. If some devices remain connected (through a switch or an extender) they might continue to use their old address (and the router might assign it to someone else).
Not getting an IP address in the first place suggests that the extender->router connection wasn't solid. If you see that with the new extender too, then look at the router link indication on the extender.
- Nathan4wvu1986Aug 27, 2018Aspirant
So the new unit from Amazon did not correct the problem. Tonight I noticed the main wifi router is running in access point mode. I guess it's been that way for months. Do you think that could cause the issue? Tomorrow I'm going to do a factory reset on the router to see if that corrects the issue. Connecting all my nest products back will be a pain, but it's my only option at this point.
