lenena's avatar
lenena
Initiate
May 21, 2016
Need advice with my EX7000 and my BOX TV
Hello, I have a LIVEBOX ( Orange ). I turned OFF his Wifi and plug a ROUTEUR "Netgear R8000-100PES Nighthawk X6 AC3200 Tri-Band". In another room I have an extender "Netgear Nighthawk AC1900 EX7000-1...
  • TheEther's avatar
    May 21, 2016
    IPTV service usually uses IP Multicast.  Log into your R8000, go to ADVANCED > Setup > WAN Setup, uncheck the Disable IGMP Proxying checkbox and click Apply.
